acp.bind events
acp.bind.error
Severity
ERROR
This message occurs when the system encounters a socket binding error while setting up the Alternate Control Path (ACP) Management Ethernet port. ACP functionality is inactive after encountering this.
Corrective Action
Verify that the Ethernet cable is properly attached to the ACP port and the green LED is on. Reenable the ACP port using the "options acp.enabled" command.
Syslog Message
An error was encountered while configuring the ACP Management Ethernet Port: %s.
ErrorString (STRING): Error string.
