scsiblade.disabled events
scsiblade.disabled
Severity
NOTICE
This message occurs when the local node is made ineligible. When this occurs, both FCP and iSCSI traffic are disabled on the local node.
Corrective Action
Modify the node's eligibility by using the (privilege: advanced) "cluster modify -eligibility true" command.
Syslog Message
The local node is ineligible. FCP and iSCSI access is disabled.
(None).
