      scsiblade.disabled events
scsiblade.disabled
- Severity
NOTICE
 - Description
This message occurs when the local node is made ineligible. When this occurs, both FCP and iSCSI traffic are disabled on the local node.
 - Corrective Action
Modify the node's eligibility by using the (privilege: advanced) "cluster modify -eligibility true" command.
 - Syslog Message
The local node is ineligible. FCP and iSCSI access is disabled.
 - Parameters
(None).
