adt.max events
adt.max.record.size.exceeded
Severity
ERROR
This message occurs when a management command or file operation tries to generate an audit record, that is greater than the max_audit_record_size value. The File Services Auditing subsystem might fail the operation or truncate the record.
Corrective Action
Contact NetApp technical support.
Syslog Message
File Services Auditing subsystem failed the operation or truncated an audit record because it was greater than max_audit_record_size value. Vserver UUID=%s, event_id=%u, size=%u
VserverUuid (STRING): UUID of then Vserver.
eventId (INT): Event ID for internal use.
size (INT): Record size.
