      adt.max events
adt.max.record.size.exceeded
- Severity
ERROR
 - Description
This message occurs when a management command or file operation tries to generate an audit record, that is greater than the max_audit_record_size value. The File Services Auditing subsystem might fail the operation or truncate the record.
 - Corrective Action
Contact NetApp technical support.
 - Syslog Message
File Services Auditing subsystem failed the operation or truncated an audit record because it was greater than max_audit_record_size value. Vserver UUID=%s, event_id=%u, size=%u
 - Parameters
VserverUuid (STRING): UUID of then Vserver.
eventId (INT): Event ID for internal use.
size (INT): Record size.
