ONTAP EMS reference
vs.multiple events
vs.multiple.adtjobs
Severity
ERROR
This message occurs when more than one Vserver audit consolidation jobs is found.
Corrective Action
Check Vserver audit configuration. If enabled, disable it using the following commands: cluster::> vserver audit show cluster::> vserver audit disable -vserver Check for Vserver audit consolidation jobs. If still present, delete the jobs using the following commands: cluster::> job show cluster::> job expunge -id Check for consolidation processes. If any still exist, kill the processes using the following commands from systemshell: > ps -auxw | grep adtcons > sudo kill -9 "pid of the process" Enable the Vserver audit configuration by using the following command: cluster::> vserver audit enable
Syslog Message
More than one Vserver audit consolidation jobs found for Vserver %s.
vserver (STRING): Name of the Vserver that has more than one consolidation job.
