cf.rsrc events
cf.rsrc.givebackFail
- Severity
ALERT
 - Description
This message occurs when a failure is detected during giveback. The giveback operation will be cancelled.
 - Corrective Action
Check the logs for other messages regarding the listed subsystem using the "event log show" CLI command. Resolve those problems and perform a planned giveback operation using "storage failover giveback" command.
 - Syslog Message
Failover monitor: giveback during %s failed; giveback cancelled.
 - Parameters
op (STRING): Name of the giveback subsystem that has suffered a fatal error.
cf.rsrc.givebackForceFail
- Severity
ERROR
 - Description
This event occurs if a failure is forced during giveback. This event should only occur in debugging kernels.
 - Corrective Action
Retry the takeover.
 - Syslog Message
Failover monitor: giveback during %s forced fail
 - Parameters
op (STRING): Name of the takeover operation
cf.rsrc.givebackForceVeto
- Severity
ERROR
 - Description
This event occurs if a veto is forced during giveback. This event should only occur in debugging kernels.
 - Corrective Action
Check the state of the subsystem listed in this message. Retry the giveback.
 - Syslog Message
Giveback during %s forced veto
 - Parameters
cf.rsrc.givebackOpFail
- Severity
ERROR
 - Description
This event occurs if a failure is detected during giveback. This error is not fatal to the giveback process but indicates that the related service could not be shutdown cleanly.
 - Corrective Action
Check the state of the subsystem listed in the message and validate it is working correctly. Validate that there are no configuration errors for the listed subsystem.
 - Syslog Message
Failover monitor: giveback during %s failed; giveback continuing…
 - Parameters
op (STRING): Name of the giveback operation that has suffered a non-fatal error.
cf.rsrc.givebackUnexpected
- Severity
ALERT
 - Description
This event occurs if we detect an unexpected failover monitor state during a giveback operation. This indicates a software bug.
 - Corrective Action
Retry the giveback.
 - Syslog Message
(None).
 - Parameters
state (INT): Value of the failover monitor state
cf.rsrc.givebackVeto
- Severity
ALERT
 - Description
This message occurs when a veto is indicated during giveback. A veto occurs when the active partner state is detected during the giveback process. A veto can be overridden by using the "cf giveback -f" or "storage failover takeover -override-vetoes true" command.
 - Corrective Action
Check the preceeding messages for reasons why the giveback was vetoed. Check the state of the subsystem listed in this message. Retry the giveback.
 - Syslog Message
Failover monitor: %s: giveback canceled due to active state.
 - Parameters
op (STRING): Name of the takeover operation.
cf.rsrc.raidReplayOnlyTODone
- Severity
INFORMATIONAL
 - Description
This event occurs when a node is booting after having panicked too soon after takeover or during takeover. In that event we want to replay the partner RAID logs, before we perform a giveback. This message indicates the point at which we have committed partner RAID logs to the disk and are now going to initiate a giveback.
 - Corrective Action
(None).
 - Syslog Message
Failover monitor: Raid replay-only takeover completed. Initiating giveback.
 - Parameters
(None).
cf.rsrc.replayOnlyTakeoverDone
- Severity
NOTICE
 - Description
This event occurs when a node is booting after having panicked too soon after takeover or during takeover. In that event we want to replay the partner logs, before we perform a giveback. This message indicates the point at which we have committed partner logs to the disk and are now going to initiate a giveback.
 - Corrective Action
(None).
 - Syslog Message
Failover monitor: replay-only takeover completed. Initiating giveback.
 - Parameters
(None).
cf.rsrc.takeoverFail
- Severity
ALERT
 - Description
This message occurs when a failure is detected during takeover. The takeover operation will be cancelled.
 - Corrective Action
Contact NetApp technical support.
 - Syslog Message
Failover monitor: takeover during %s failed; takeover cancelled.
 - Parameters
op (STRING): Name of the takeover operation that has suffered a fatal error.
cf.rsrc.takeoverForceFail
- Severity
ERROR
 - Description
This event occurs if a failure is forced during takeover. This event should only occur in debugging kernels.
 - Corrective Action
Retry the takeover request.
 - Syslog Message
Failover monitor: takeover during %s forced fail
 - Parameters
cf.rsrc.takeoverOpFail
- Severity
ERROR
 - Description
This event occurs if a failure is detected during takeover. This error is not fatal to the takeover process but indicates that the related service may be inaccessible during takeover of the partner.
 - Corrective Action
After takeover completes, check the state of the subsystem listed in the message. Check that the configuration of the subsystem listed in the messsage is correct.
 - Syslog Message
Failover monitor: takeover during %s failed; takeover continuing…
 - Parameters
op (STRING): Name of the takeover operation that has suffered a non-fatal error.
cf.rsrc.takeoverUnexpected
- Severity
ERROR
 - Description
This event occurs if we detect an unexpected failover monitor state during a takeover operation. This indicates a software bug.
 - Corrective Action
Check the state of the subsystem listed in 'op' parameter. Retry the giveback.
 - Syslog Message
(None).
 - Parameters
