The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
asyncdelete.cancel events
Creating your file...
Your file is ready
asyncDelete.cancel.start
- Severity
NOTICE
- Description
This message occurs when cancellation of async delete jobs is started on a node due to Vserver migrate operation. The administrator will need to restart the jobs after the migration is complete or aborted.
- Corrective Action
The administrator will need to restart the cancelled async delete jobs after the migration is complete or aborted. Command to start an async-delete job: "volume file async-delete start -volume <volume-name< -vserver <vserver-name< -path <directory path<".
- Syslog Message
Cancellation of async delete jobs was started on node "%s" because of Vserver migration. The administrator will need to restart the jobs after the migration is complete or aborted.
- Parameters
Node (STRING): Node where async delete jobs are running.
