asyncdelete.cancel events
Creating your file...
Your file is ready
asyncDelete.cancel.start
- Severity
NOTICE
- Description
This message occurs when cancellation of async delete jobs is started on a node due to Vserver migrate operation. The administrator will need to restart the jobs after the migration is complete or aborted.
- Corrective Action
The administrator will need to restart the cancelled async delete jobs after the migration is complete or aborted. Command to start an async-delete job: "volume file async-delete start -volume <volume-name< -vserver <vserver-name< -path <directory path<".
- Syslog Message
Cancellation of async delete jobs was started on node "%s" because of Vserver migration. The administrator will need to restart the jobs after the migration is complete or aborted.
- Parameters
Node (STRING): Node where async delete jobs are running.
