siw.mpaversionmismatch events
siw.mpaVersionMismatch
Severity
ALERT
This message occurs when there is SW-iWARP Version mismatch between the HA nodes. SW-iWARP cannot start up and nodes are not connected.
Corrective Action
Upgrade the ONTAP® release on the nodes to the same version of SW-iWARP to bring up the SW-iWARP and connect the nodes.
Syslog Message
SW-iWARP version mismatch between the local node and the partner node.
(None).
