The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
siw.mpaversionmismatch events
Creating your file...
Your file is ready
siw.mpaVersionMismatch
- Severity
ALERT
- Description
This message occurs when there is SW-iWARP Version mismatch between the HA nodes. SW-iWARP cannot start up and nodes are not connected.
- Corrective Action
Upgrade the ONTAP® release on the nodes to the same version of SW-iWARP to bring up the SW-iWARP and connect the nodes.
- Syslog Message
SW-iWARP version mismatch between the local node and the partner node.
- Parameters
(None).
