ONTAP EMS reference
coredump.segment events
coredump.segment EMS events occur when ONTAP encounters issues associated with segmenting core files.
coredump.segment.auto.fail
Severity
NOTICE
This message occurs when the system enounters an error while trying to send a core segment request.
Corrective Action
(None).
Syslog Message
Failed to start automatic segmenting for core file, %s , for host %d.
file (STRING): Name of the core file that would have been segmented.
host (INT): Host that owns the core file.
coredump.segment.auto.pfail
Severity
INFORMATIONAL
This message occurs when the system cannot start the segmenting of a core file because the node is no longer in takeover mode.
Corrective Action
(None).
Syslog Message
Cannot start segmenting a core file, %s. Node is no longer in takeover mode.
file (STRING): Name of core file that would have been segmented.
coredump.segment.completed
Severity
NOTICE
This message occurs when the segmenting of a full core file has been completed.
Corrective Action
(None).
Syslog Message
Saved core segment %s for node %s. Core size is %llu bytes and core data checksum is %s.
file (STRING): Name of the core file segmented.
node (STRING): Name of the node whose core segment was saved.
size (LONGINT): Size of core segment in bytes.
chksum (STRING): Checksum of the core segment file's data.
