coredump.segment events
coredump.segment EMS events occur when ONTAP encounters issues associated with segmenting core files.
coredump.segment.auto.fail
- Severity
NOTICE
- Description
This message occurs when the system enounters an error while trying to send a core segment request.
- Corrective Action
(None).
- Syslog Message
Failed to start automatic segmenting for core file, %s , for host %d.
- Parameters
file (STRING): Name of the core file that would have been segmented.
host (INT): Host that owns the core file.
coredump.segment.auto.pfail
- Severity
INFORMATIONAL
- Description
This message occurs when the system cannot start the segmenting of a core file because the node is no longer in takeover mode.
- Corrective Action
(None).
- Syslog Message
Cannot start segmenting a core file, %s. Node is no longer in takeover mode.
- Parameters
file (STRING): Name of core file that would have been segmented.
coredump.segment.completed
- Severity
NOTICE
- Description
This message occurs when the segmenting of a full core file has been completed.
- Corrective Action
(None).
- Syslog Message
Saved core segment %s for node %s. Core size is %llu bytes and core data checksum is %s.
- Parameters
file (STRING): Name of the core file segmented.
node (STRING): Name of the node whose core segment was saved.
size (LONGINT): Size of core segment in bytes.
chksum (STRING): Checksum of the core segment file's data.
