The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
air.vplus events
Creating your file...
Your file is ready
air.vplus.certify.issue
- Severity
NOTICE
- Description
This message occurs when an inconsistency is discovered inside an indexed storage tree. The inconsistency is automatically repaired immediately upon detection.
- Corrective Action
(None).
- Syslog Message
AIR vplus certification of %s failed: %s, %s for subtype %d
- Parameters
fh (STRING): File handle of the storage tree.
condition (STRING): Specific metadata validation test that failed.
source (STRING): Location of the failing metadata validation test.
subtype (INT): Subtype of the inode encountering the inconsistency.
