ONTAP EMS reference
crypto.okmrecovery events
crypto.okmrecovery.failed
Severity
ALERT
This message occurs when the boot menu OKM recovery command fails to recover the onboard key hierarchy.
Corrective Action
This message is usually seen when an incorrect cluster passphrase was entered during a previous boot menu recovery command. To recover the key hierarchy, enter option 10 at the boot menu prompt. You will need to have the cluster passphrase and a copy of the output from the "security key-manager backup show" command. If the boot menu recovery process fails again, contact NetApp technical support.
Syslog Message
ERROR: Import of the onboard key hierarchy failed: %s. Additional information: %s.
failure_msg (STRING): Message describing what operation failed.
additional_msg (STRING): Additional information regarding the failure.
