      crypto.okmrecovery events
crypto.okmrecovery.failed
- Severity
ALERT
 - Description
This message occurs when the boot menu OKM recovery command fails to recover the onboard key hierarchy.
 - Corrective Action
This message is usually seen when an incorrect cluster passphrase was entered during a previous boot menu recovery command. To recover the key hierarchy, enter option 10 at the boot menu prompt. You will need to have the cluster passphrase and a copy of the output from the "security key-manager backup show" command. If the boot menu recovery process fails again, contact NetApp technical support.
 - Syslog Message
ERROR: Import of the onboard key hierarchy failed: %s. Additional information: %s.
 - Parameters
failure_msg (STRING): Message describing what operation failed.
additional_msg (STRING): Additional information regarding the failure.
