cache.ttl events
cache.ttl.settings.change
Severity
ERROR
This message occurs on the last node during the upgrade to ONTAP® 9.3, if the default TTL values of any of the SecD or NFS export caches are changed.
Corrective Action
Use the "vserver services name-service cache" commands to configure TTL values after the system is fully upgraded to ONTAP 9.3.
Syslog Message
One or more default cache TTL values for SecD and NFS export caches have been changed.
(None).
