cache.ttl events
cache.ttl.settings.change
- Severity
ERROR
- Description
This message occurs on the last node during the upgrade to ONTAP® 9.3, if the default TTL values of any of the SecD or NFS export caches are changed.
- Corrective Action
Use the "vserver services name-service cache" commands to configure TTL values after the system is fully upgraded to ONTAP 9.3.
- Syslog Message
One or more default cache TTL values for SecD and NFS export caches have been changed.
- Parameters
(None).
