acp.shelf events
Creating your file...
acp.shelf.power.cycle.failed
- Severity
INFORMATIONAL
- Description
This message occurs when the Alternate Control Path (ACP) Processor fails to complete a power cycle of the disk shelf.
- Corrective Action
(None).
- Syslog Message
Disk shelf power cycle request issued to %s failed because %s.
- Parameters
shelf_id (STRING): In-band ID or Shelf Serial Number of the module.
status (STRING): Reason for failure.
acp.shelf.power.cycle.success
- Severity
INFORMATIONAL
- Description
This message occurs when the Alternate Control Path (ACP) Processor successfully completes a power cycle of the disk shelf.
- Corrective Action
(None).
- Syslog Message
Disk shelf power cycle request issued to %s is successful.
- Parameters
acp.shelf.power.off
- Severity
INFORMATIONAL
- Description
This message occurs when the Alternate Control Path (ACP) Processor receives a command to power off the disk shelf.
- Corrective Action
(None).
- Syslog Message
Disk shelf power off request issued to %s
- Parameters
shelf_id (STRING): In-band ID of the module or Shelf Serial Number.
acp.shelf.power.off.failed
- Severity
INFORMATIONAL
- Description
This message occurs when the Alternate Controller Path Administrator fails in its attempt to power-off the SAS disk shelf.
- Corrective Action
(None).
- Syslog Message
Disk shelf power off request sent to %s failed with status %s
- Parameters
shelf_id (STRING): In-band ID of the module.
status (STRING): Reason for the power-off failure.
acp.shelf.power.off.success
- Severity
INFORMATIONAL
- Description
This message occurs when a 'shelf power off' command sent to the Alternate Controller Path (ACP) Processor succeeds.
- Corrective Action
(None).
- Syslog Message
Disk shelf power off command sent to %s was successful
- Parameters
acp.shelf.power.on
- Severity
INFORMATIONAL
- Description
This message occurs when the Alternate Control Path (ACP) Processor receives a command to power on a disk shelf.
- Corrective Action
(None).
- Syslog Message
Disk shelf power up request issued to %s
- Parameters
acp.shelf.power.on.failed
- Severity
INFORMATIONAL
- Description
This message occurs when the Alternate Controller Path Administrator fails in its attempt to power on the SAS disk shelf.
- Corrective Action
(None).
- Syslog Message
Disk shelf power on request sent to %s failed with status %s
- Parameters
status (STRING): Reason for the 'power-on' failure.
acp.shelf.power.on.success
- Severity
INFORMATIONAL
- Description
This message occurs when a 'shelf power on' command sent to the Alternate Controller Path (ACP) Processor succeeds.
- Corrective Action
(None).
- Syslog Message
Disk shelf power on command sent to %s was successful
- Parameters
