sv.vfiler events
SV.vfiler.config.move.error
Severity
ERROR
This message occurs when movement of SnapVault® configuration from 'from' vFiler to 'to' vFiler fails. Subsequent SnapVault transfer on the vFiler might fail.
Corrective Action
Move the volume back to 'from' vFiler and then again perform a vFiler move from 'from' vFiler to 'to' vFiler. Please use 'vfiler move' command to move the volume between the vfilers.
Syslog Message
Movement of SnapVault configuration failed while moving volumes between vFiler %s to vFiler %s. Move the volume back to %s vFiler and perform the vFiler move operation again.
from_vfiler1 (STRING): vFiler(tm) from which resources are being moved.
to_vfiler (STRING): vFiler to which resources are being moved.
from_vfiler2 (STRING): vFiler to which resources are being moved.
