sv.vfiler events
Creating your file...
Your file is ready
SV.vfiler.config.move.error
- Severity
ERROR
- Description
This message occurs when movement of SnapVault® configuration from 'from' vFiler to 'to' vFiler fails. Subsequent SnapVault transfer on the vFiler might fail.
- Corrective Action
Move the volume back to 'from' vFiler and then again perform a vFiler move from 'from' vFiler to 'to' vFiler. Please use 'vfiler move' command to move the volume between the vfilers.
- Syslog Message
Movement of SnapVault configuration failed while moving volumes between vFiler %s to vFiler %s. Move the volume back to %s vFiler and perform the vFiler move operation again.
- Parameters
from_vfiler1 (STRING): vFiler(tm) from which resources are being moved.
to_vfiler (STRING): vFiler to which resources are being moved.
from_vfiler2 (STRING): vFiler to which resources are being moved.
