cr.data events
CR.Data.File.Inaccessible
Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
Severity
NOTICE
This message occurs when the namespace scanner skips an inode for which it cannot access the data file. This might be due to the data volume being offline.
Corrective Action
Bring the data volume back online using the "volume online" command. If the problem persists, retry the scan operation.
Syslog Message
The redirector file [%s] on namespace volume [%s] will be skipped by "Volume Check" because the corresponding data file on data volume [%s] in Vserver [%s] is not accessible.
redirPath (STRING): Path of the redirector file that will be skipped.
nsVol (STRING): Name of the constituent namespace volume that hosts the redirector file.
dataVol (STRING): Name of the constituent data volume that hosts the data file.
vserver (STRING): Vserver hosting the constituent volumes.
