cr.data events
cr.data EMS events occur when the namespace scanner skips an inode for which it cannot access the data file.
CR.Data.File.Inaccessible
- Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
- Severity
NOTICE
- Description
This message occurs when the namespace scanner skips an inode for which it cannot access the data file. This might be due to the data volume being offline.
- Corrective Action
Bring the data volume back online using the "volume online" command. If the problem persists, retry the scan operation.
- Syslog Message
The redirector file [%s] on namespace volume [%s] will be skipped by "Volume Check" because the corresponding data file on data volume [%s] in Vserver [%s] is not accessible.
- Parameters
redirPath (STRING): Path of the redirector file that will be skipped.
nsVol (STRING): Name of the constituent namespace volume that hosts the redirector file.
dataVol (STRING): Name of the constituent data volume that hosts the data file.
vserver (STRING): Vserver hosting the constituent volumes.
