vserver.name events
vserver.name.conflict.local
Severity
NOTICE
This message occurs when use of the "vserver rename" command creates a Vserver name conflict in the local cluster, and the local cluster resolves the name conflict by incorporating the Vserver Unique Identifier (UID) into the name. This creates a new and unique Vserver name, but that new name is not the name specified in the original rename command.
Corrective Action
None
Syslog Message
Vserver name conflict in local cluster with existing local or peer Vserver %s. Local cluster has assigned unique Vserver name %s
vserver_name (STRING): Vserver name that caused the renaming conflict.
unique_vserver_name (STRING): Unique Vserver name that Local cluster has assigned.
vserver.name.conflict.peer
Severity
NOTICE
This message occurs when use of the "vserver rename" command creates a Vserver name conflict in the peer cluster, and the peer cluster resolves the name conflict by incorporating the Vserver Unique Identifier (UID) into the name. This creates a new and unique Vserver name, but that new name is not the name specified in the original rename command.
Corrective Action
None
Syslog Message
Vserver name conflict occured in peer cluster %s with existing local or peer Vserver %s. Peer cluster has assigned unique Vserver name %s.
peer_cluster (STRING): Peer cluster name.
unique_vsname (STRING): Unique Vserver name that Peer cluster has assigned.
