vserver.name events
Creating your file...
vserver.name.conflict.local
- Severity
NOTICE
- Description
This message occurs when use of the "vserver rename" command creates a Vserver name conflict in the local cluster, and the local cluster resolves the name conflict by incorporating the Vserver Unique Identifier (UID) into the name. This creates a new and unique Vserver name, but that new name is not the name specified in the original rename command.
- Corrective Action
None
- Syslog Message
Vserver name conflict in local cluster with existing local or peer Vserver %s. Local cluster has assigned unique Vserver name %s
- Parameters
vserver_name (STRING): Vserver name that caused the renaming conflict.
unique_vserver_name (STRING): Unique Vserver name that Local cluster has assigned.
vserver.name.conflict.peer
- Severity
NOTICE
- Description
This message occurs when use of the "vserver rename" command creates a Vserver name conflict in the peer cluster, and the peer cluster resolves the name conflict by incorporating the Vserver Unique Identifier (UID) into the name. This creates a new and unique Vserver name, but that new name is not the name specified in the original rename command.
- Corrective Action
None
- Syslog Message
Vserver name conflict occured in peer cluster %s with existing local or peer Vserver %s. Peer cluster has assigned unique Vserver name %s.
- Parameters
peer_cluster (STRING): Peer cluster name.
unique_vsname (STRING): Unique Vserver name that Peer cluster has assigned.
