The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
mpt.action events
Creating your file...
Your file is ready
mpt.action.reset.bus
- Severity
NOTICE
- Description
This message occurs when the system bus is reset in the message processing technology (MPT) adapter driver.
- Corrective Action
(None).
- Syslog Message
Bus reset on path %s for device status %s.
- Parameters
path (STRING): Device path.
msg (STRING): Detail about device status.
mpt.action.reset.dev
- Severity
NOTICE
- Description
This message occurs when the system device is reset in the message processing technology (MPT) adapter driver.
- Corrective Action
(None).
- Syslog Message
Device reset on path %s for device status %s.
- Parameters
