cr.fix events
CR.Fix.Corrupt.Redir.Failed
Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
Severity
NOTICE
This message occurs when corrective action for corrupt redirector file failed.
Corrective Action
(None).
Syslog Message
Corrective action failed for corrupt redirector of data file [%s] on volume [%s] in Vserver [%s].
path (STRING): File path.
volume (STRING): Name of the constituent volume where the data file resides.
vserver (STRING): Vserver hosting the volume.
CR.Fix.Crpt.Data.Dir.Failed
Deprecated
Severity
INFORMATIONAL
This message occurs when the corrective action for a corrupt data directory fails. These entries were created when they were moved to the [lost+found] folder by waflIron, on the data constituents.
Corrective Action
(None).
Syslog Message
Corrective action failed for corrupt data directory [%s] on volume [%s].
path (STRING): Directory path.
volume (STRING): Name of the constituent volume where the directory resides.
CR.Fix.Crpt.Data.File.Failed
Deprecated
Severity
NOTICE
This message occurs when the corrective action for a corrupt data file fails.
Corrective Action
(None).
Syslog Message
Corrective action failed for corrupt data file [%s] on volume [%s] in Vserver [%s].
volume (STRING): Name of the constituent volume where the file resides.
CR.Fix.CrptStreamRedir.Fail
Deprecated
Severity
NOTICE
This message occurs when the fix for corrupt stream redirector fails.
Corrective Action
(None).
Syslog Message
Corrective action failed for corrupt stream redirector of stream data [%s] on volume [%s] in Vserver [%s].
path (STRING): Stream path.
volume (STRING): Name of the constituent volume where the stream redirector resides.
CR.Fix.Dang.Data.File.Failed
Deprecated
Severity
NOTICE
This message occurs when the corrective action for a dangling data file fails. This file was created when there was a failure in cleaning up a file on the data constituent, which left a dangling file that is unnecessarily consuming resources.
Corrective Action
(None).
Syslog Message
Corrective action failed for dangling data file [%s] on volume [%s] in Vserver [%s].
Deprecated
Severity
NOTICE
This message occurs when the corrective action for an Nlinks (number of hardlinks on the file) mismatch fails.
Corrective Action
(None).
Syslog Message
Corrective action failed for Nlinks mismatch on file [%s] on volume [%s] in Vserver [%s].
