cr.fix events
cr.fix EMS events occur when ONTAP encounters issues associated with correcting corrupt or dangling files and redirectors.
CR.Fix.Corrupt.Redir.Failed
- Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
- Severity
NOTICE
- Description
This message occurs when corrective action for corrupt redirector file failed.
- Corrective Action
(None).
- Syslog Message
Corrective action failed for corrupt redirector of data file [%s] on volume [%s] in Vserver [%s].
- Parameters
path (STRING): File path.
volume (STRING): Name of the constituent volume where the data file resides.
vserver (STRING): Vserver hosting the volume.
CR.Fix.Crpt.Data.Dir.Failed
- Deprecated
- Severity
INFORMATIONAL
- Description
This message occurs when the corrective action for a corrupt data directory fails. These entries were created when they were moved to the [lost+found] folder by waflIron, on the data constituents.
- Corrective Action
(None).
- Syslog Message
Corrective action failed for corrupt data directory [%s] on volume [%s].
- Parameters
path (STRING): Directory path.
volume (STRING): Name of the constituent volume where the directory resides.
CR.Fix.Crpt.Data.File.Failed
- Deprecated
- Severity
NOTICE
- Description
This message occurs when the corrective action for a corrupt data file fails.
- Corrective Action
(None).
- Syslog Message
Corrective action failed for corrupt data file [%s] on volume [%s] in Vserver [%s].
- Parameters
volume (STRING): Name of the constituent volume where the file resides.
CR.Fix.CrptStreamRedir.Fail
- Deprecated
- Severity
NOTICE
- Description
This message occurs when the fix for corrupt stream redirector fails.
- Corrective Action
(None).
- Syslog Message
Corrective action failed for corrupt stream redirector of stream data [%s] on volume [%s] in Vserver [%s].
- Parameters
path (STRING): Stream path.
volume (STRING): Name of the constituent volume where the stream redirector resides.
CR.Fix.Dang.Data.File.Failed
- Deprecated
- Severity
NOTICE
- Description
This message occurs when the corrective action for a dangling data file fails. This file was created when there was a failure in cleaning up a file on the data constituent, which left a dangling file that is unnecessarily consuming resources.
- Corrective Action
(None).
- Syslog Message
Corrective action failed for dangling data file [%s] on volume [%s] in Vserver [%s].
- Parameters
CR.Fix.Nlinks.Failed
- Deprecated
- Severity
NOTICE
- Description
This message occurs when the corrective action for an Nlinks (number of hardlinks on the file) mismatch fails.
- Corrective Action
(None).
- Syslog Message
Corrective action failed for Nlinks mismatch on file [%s] on volume [%s] in Vserver [%s].
- Parameters
