ONTAP EMS reference
disk.uid events
disk.uid EMS events occur when a SCSI (Small Computer System Interface) INQUIRY command done during a disk drive initialization sequence finds different data in the INQUIRY response for page 0x83.
disk.uid.changed
Severity
NOTICE
This message occurs when a SCSI (Small Computer System Interface) INQUIRY command done during a disk drive initialization sequence finds different data in the INQUIRY response for page 0x83. The unique id (UID) derived from this information has changed unexpectedly.
Corrective Action
Locate the failed disk drive by looking for a disk drive whose amber LED fault light is lit. Replace the disk drive.
Syslog Message
Disk %s has unexpectedly changed its unique ID. vendor:%s product:%s serial_number:%s
diskName (STRING): Name of the disk that had the UID change.
disk_vendor_id (STRING): Vendor name of the disk that had the UID change.
disk_product_id (STRING): Product name of the disk that had the UID change.
disk_serialno (STRING): Serial number of the disk that had the UID change.
