The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
rlib.remote events
Creating your file...
Your file is ready
rlib.remote.node.event
- Severity
NOTICE
- Description
This event is generated to print information about remote node such as IP address and sysid along with the event that occurred
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
peerIP (STRING): IP address of remote node
peerSysid (LONGINT): Sysid of remote node
localIP (STRING): IP address of local node
localPort (STRING): Local rdma port name
eventDesc (STRING): Information about the event (Optional)
rlib.remote.node.update
- Severity
NOTICE
- Description
This event is generated when remote node sysid has changed as a part of headswap
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
oldSysid (LONGINT): Old sysid of remote node
sysid (LONGINT): New sysid of remote node
