ONTAP EMS reference
flexcache.origin events
flexcache.origin EMS events occur when ONTAP encounters issues associated with FlexCache origin volume configuration synchronization.
flexcache.origin.config.sync.failed
Severity
ERROR
This message occurs when the origin of the FlexCache volume expand operation fails to synchronize the configuration information between the newly created constituent volume and the cache cluster.
Corrective Action
Use the "volume flexcache config-refresh" command on the cache cluster to update the origin of the FlexCache configuration.
Syslog Message
Volume expand failed to create the origin configuration for the origin of the FlexCache volume "%s" in Vserver "%s" on the FlexCache cluster. Error: %s.
originVolName (STRING): Name of the origin of the FlexCache volume.
cacheVserver (STRING): Name of the Vserver hosting the origin of the FlexCache volume.
errorString (STRING): Error string.
