ONTAP EMS reference
flexcache.origin events
flexcache.origin.config.sync.failed
Severity
ERROR
This message occurs when the origin of the FlexCache volume expand operation fails to synchronize the configuration information between the newly created constituent volume and the cache cluster.
Corrective Action
Use the "volume flexcache config-refresh" command on the cache cluster to update the origin of the FlexCache configuration.
Syslog Message
Volume expand failed to create the origin configuration for the origin of the FlexCache volume "%s" in Vserver "%s" on the FlexCache cluster. Error: %s.
originVolName (STRING): Name of the origin of the FlexCache volume.
cacheVserver (STRING): Name of the Vserver hosting the origin of the FlexCache volume.
errorString (STRING): Error string.
flexcache.origin.size.sync.failed.disconnected.mode
Severity
ERROR
This message occurs when syncing the size property of the origin volume between an origin of a FlexCache volume and its FlexCache volume fails because the cluster containing the FlexCache volume is not reachable.
Corrective Action
Make sure that the cluster containing the FlexCache volume is reachable. Make sure that the FlexCache cluster and the origin of the FlexCache cluster are running on the same ONTAP® build.
Syslog Message
Failed to sync origin size property for FlexCache Cluster "%s". Error: %s
originClusterUuid (STRING): Cache Cluster UUID.
flexcache.origin.size.sync.failed.for.cache.cluster
Severity
ERROR
This message occurs when syncing the size property of the origin volume between an origin of a FlexCache volume and its FlexCache volume fails because we encountered some error on the cluster containing the FlexCache volume.
Corrective Action
Look for an EMS on the cache cluster and take the corrective action needed. Make sure that the FlexCache cluster and the origin of the FlexCache cluster are running on the same ONTAP® build.
Syslog Message
Failed to sync origin size property for Cache Cluster "%s".
cacheClusterUuid (STRING): Cache Cluster UUID.
flexcache.origin.size.sync.failed.for.cache.volume
Severity
ERROR
This message occurs when syncing the size property of the origin volume between an origin of a FlexCache volume and its FlexCache volume fails, and the sync operation will be retried.
Corrective Action
Take the appropriate action depending on the error message. Make sure that the FlexCache cluster and the origin of the FlexCache cluster are running on the same ONTAP® build.
Syslog Message
Failed to sync origin size property for FlexCache volume "%s" in Vserver "%s". Error: %s.
volumeName (STRING): Cache Volume Name.
vserverName (STRING): Cache Vserver Name.
