The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
ses.system events
Creating your file...
Your file is ready
ses.system.em.mmErr
- Severity
EMERGENCY
- Description
This message occurs when ONTAP® software does not support internal disk drives in this platform.
- Corrective Action
Check with NetApp technical support whether the combination of this platform type with internal disks is sopported on a later version of ONTAP. If so, upgrade to the appropriate ONTAP version.
- Syslog Message
Disk shelf %d containing a %.8s system with internal drives (product ID %.16s) is not a supported combination.
- Parameters
ShelfID (INT): ID of the disk shelf.
VendorID (STRING): Vendor ID of the disk shelf.
ProductID (STRING): Product ID of the disk shelf.
