ses.system events
ses.system EMS events occur when ONTAP® software does not support internal disk drives in this platform.
ses.system.em.mmErr
- Severity
EMERGENCY
- Description
This message occurs when ONTAP® software does not support internal disk drives in this platform.
- Corrective Action
Check with NetApp technical support whether the combination of this platform type with internal disks is sopported on a later version of ONTAP. If so, upgrade to the appropriate ONTAP version.
- Syslog Message
Disk shelf %d containing a %.8s system with internal drives (product ID %.16s) is not a supported combination.
- Parameters
ShelfID (INT): ID of the disk shelf.
VendorID (STRING): Vendor ID of the disk shelf.
ProductID (STRING): Product ID of the disk shelf.
