connectx.portdisabled events
connectx.portDisabled
Severity
ALERT
This message occurs when the HA interconnect port experiences persistent node advertisement send timeouts. Port reinitialization does not correct the problem. The port is disabled.
Corrective Action
Reboot the controller. Contact NetApp technical support if the problem persists.
Syslog Message
Node advertisement send timed out for the ConnectX device in slot %d, port %d. The port is disabled. Device registers have been dumped to the /etc/mlxlog/ConnectX_regdump file.
phys_slot (INT): Physical slot in which ConnectX is present.
port_num (INT): Port number that is disabled.
