      connectx.portdisabled events
connectx.portDisabled
- Severity
ALERT
 - Description
This message occurs when the HA interconnect port experiences persistent node advertisement send timeouts. Port reinitialization does not correct the problem. The port is disabled.
 - Corrective Action
Reboot the controller. Contact NetApp technical support if the problem persists.
 - Syslog Message
Node advertisement send timed out for the ConnectX device in slot %d, port %d. The port is disabled. Device registers have been dumped to the /etc/mlxlog/ConnectX_regdump file.
 - Parameters
phys_slot (INT): Physical slot in which ConnectX is present.
port_num (INT): Port number that is disabled.
