ONTAP EMS reference
config.habadbank1 events
config.habadbank1 EMS events occur when a local host adapter is connected to a different switch bank (on ports 8-15) than other adapters on this controller, which are connected to ports 0-7.
config.HABadBank1
Severity
ALERT
This message occurs when a local host adapter is connected to a different switch bank (on ports 8-15) than other adapters on this controller, which are connected to ports 0-7. This is an illegal configuration.
Corrective Action
Connect all of the adapters of this controller to the same bank of switch ports.
Syslog Message
Other local host adapters are connected to Switch bank 1 (ports 0-7). Host adapter %s is connected to Switch bank 2 (ports 8-15). This is an illegal configuration.
ha (STRING): Name of the host adapter.
