config.habadbank1 events
Creating your file...
Your file is ready
config.HABadBank1
- Severity
ALERT
- Description
This message occurs when a local host adapter is connected to a different switch bank (on ports 8-15) than other adapters on this controller, which are connected to ports 0-7. This is an illegal configuration.
- Corrective Action
Connect all of the adapters of this controller to the same bank of switch ports.
- Syslog Message
Other local host adapters are connected to Switch bank 1 (ports 0-7). Host adapter %s is connected to Switch bank 2 (ports 8-15). This is an illegal configuration.
- Parameters
ha (STRING): Name of the host adapter.
