nvram.excessive events
nvram.excessive.cecc.errs
Severity
ALERT
This message occurs when excessive correctable error-correcting code (ECC) memory errors are reported by the NVRAM complex.
Corrective Action
Use the "system environment sensors show -hidden true" cluster shell command to view the current "NV Correctable ECC count" and "NV Correctable ECC rate" values. Contact NetApp technical support for further assistance.
Syslog Message
Excessive correctable ECC errors in the NVRAM card.
(None).
nvram.excessive.sbit.ecc.errs
Deprecated
Deprecated as of version 9.2.0 to address the EMS ID length violation.
Severity
ALERT
This event is issued to report excessive singlebit ECC errors.
Corrective Action
(None).
Syslog Message
Excessive singlebit ECC errors in the NVRAM card
(None).
