The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
nvram.excessive events
Creating your file...
Your file is ready
nvram.excessive.cecc.errs
- Severity
ALERT
- Description
This message occurs when excessive correctable error-correcting code (ECC) memory errors are reported by the NVRAM complex.
- Corrective Action
Use the "system environment sensors show -hidden true" cluster shell command to view the current "NV Correctable ECC count" and "NV Correctable ECC rate" values. Contact NetApp technical support for further assistance.
- Syslog Message
Excessive correctable ECC errors in the NVRAM card.
- Parameters
(None).
nvram.excessive.sbit.ecc.errs
- Deprecated
Deprecated as of version 9.2.0 to address the EMS ID length violation.
- Severity
ALERT
- Description
This event is issued to report excessive singlebit ECC errors.
- Corrective Action
(None).
- Syslog Message
Excessive singlebit ECC errors in the NVRAM card
- Parameters
(None).
