nvram.excessive events
nvram.excessive.cecc.errs
- Severity
ALERT
- Description
This message occurs when excessive correctable error-correcting code (ECC) memory errors are reported by the NVRAM complex.
- Corrective Action
Use the "system environment sensors show -hidden true" cluster shell command to view the current "NV Correctable ECC count" and "NV Correctable ECC rate" values. Contact NetApp technical support for further assistance.
- Syslog Message
Excessive correctable ECC errors in the NVRAM card.
- Parameters
(None).
nvram.excessive.sbit.ecc.errs
- Deprecated
Deprecated as of version 9.2.0 to address the EMS ID length violation.
- Severity
ALERT
- Description
This event is issued to report excessive singlebit ECC errors.
- Corrective Action
(None).
- Syslog Message
Excessive singlebit ECC errors in the NVRAM card
- Parameters
(None).
