ONTAP EMS reference
repository.dc events
Repository.DC.Dangling.Lock
Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
Severity
ERROR
This message occurs during a client file operation request, when the Infinite Volume runs into failures that prevent it from cleaning up a transient or client-originated lock on the data constituent. If there are enough of these dangling locks on the data constituent, the lock resource might be exhausted, which causes certain operations to fail.
Corrective Action
Clear the reported lock ID by using the 'vserver locks break' command at the advanced privilege level.
Syslog Message
Failures prevented the cleanup of a lock with UUID %s on the data constituent in Vserver %u.
lockid (STRING): Lock UUID of the lock that is left dangling.
vserverId (INT): Vserver ID for which the error occurred.
