ONTAP EMS reference
nvmf.qos events
nvmf.qos EMS events occur when ONTAP encounters issues associated with NVMe over Fabrics (NVMe-oF) quality of service (QoS) policies.
nvmf.qos.mismatched.policy
Severity
ERROR
This message occurs when an NVMe-oF target subsystem contains namespaces that have different QoS policies.
Corrective Action
Determine which volumes exist within the named subsystem NQN by using the "vserver nvme subsystem map show" command. Verify that these volumes share the same QoS policy by using the "volume show -fields name,qos-policy-group" command.
Syslog Message
NVMe-oF target subsystem NQN %s contains %d namespaces that do not have the same QoS policy.
subsystem_nqn (STRING): NVMe Qualified Name (NQN) of the subsystem.
ns_count (INT): Number of namespaces that do not match.
nvmf.qos.viodet.regfail
Severity
ERROR
This message occurs when the Quality-of-Service (QoS) subsystem fails to register for updates during initialization due to an internal error (e.g. there is not enough system memory available). As a result, workloads might not meet their minimum throughput or their service-level objectives (SLOs).
Corrective Action
The registration will continue to be retried. If this message continues to occur, perform a planned takeover/giveback sequence to reset the reporting node nondisruptively by using the "takeover -ofnode (reporting_node)" and "giveback -ofnode (reporting_node)" commands. If the problem persists, contact Contact NetApp technical support..
Syslog Message
Failed to register for violation detection updates. QoS min-throughput might operate in a limited capacity.
errorCode (INT): Error code that was returned during registration.
