nvmf.qos events
nvmf.qos.mismatched.policy
- Severity
ERROR
 - Description
This message occurs when an NVMe-oF target subsystem contains namespaces that have different QoS policies.
 - Corrective Action
Determine which volumes exist within the named subsystem NQN by using the "vserver nvme subsystem map show" command. Verify that these volumes share the same QoS policy by using the "volume show -fields name,qos-policy-group" command.
 - Syslog Message
NVMe-oF target subsystem NQN %s contains %d namespaces that do not have the same QoS policy.
 - Parameters
subsystem_nqn (STRING): NVMe Qualified Name (NQN) of the subsystem.
ns_count (INT): Number of namespaces that do not match.
nvmf.qos.viodet.regfail
- Severity
ERROR
 - Description
This message occurs when the Quality-of-Service (QoS) subsystem fails to register for updates during initialization due to an internal error (e.g. there is not enough system memory available). As a result, workloads might not meet their minimum throughput or their service-level objectives (SLOs).
 - Corrective Action
The registration will continue to be retried. If this message continues to occur, perform a planned takeover/giveback sequence to reset the reporting node nondisruptively by using the "takeover -ofnode (reporting_node)" and "giveback -ofnode (reporting_node)" commands. If the problem persists, contact Contact NetApp technical support..
 - Syslog Message
Failed to register for violation detection updates. QoS min-throughput might operate in a limited capacity.
 - Parameters
errorCode (INT): Error code that was returned during registration.
