The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
ucm.disabled events
Creating your file...
Your file is ready
ucm.disabled.slot
- Severity
ERROR
- Description
This message occurs when the Unified Target Adapter reads an invalid mode from flash memory. The valid supported modes are FC (0x1) or CNA (0x2). The adapter's flash memory has failed or has been corrupted. The adapter will be disabled.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
Disabling adapter %s because invalid mode %d was read from nonvolatile memory.
- Parameters
adapter (STRING): Name of the affected adapter.
faultyMode (INT): Value of the mode read from flash memory.
