ONTAP EMS reference
cr.snapshot events
cr.snapshot EMS events occur when a temporary Snapshot(tm) copy created by the 'volume check' command could not be deleted.
CR.Snapshot.Not.Deleted
Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
Severity
NOTICE
This message occurs when a temporary Snapshot(tm) copy created by the 'volume check' command could not be deleted.
Corrective Action
Delete the Snapshot copy by using the following command from "diag" mode: volume snapshot delete -vserver <vserver> -volume <volume> -snapshot <snapshot-name> -ignore-owners
Syslog Message
The temporary Snapshot copy [%s] created by the 'volume check' command for volume [%s] in Vserver [%s] could not be deleted [error: %s].
snapshot (STRING): Name of the Snapshot copy.
volume (STRING): Name of the constituent volume for which the Snapshot copy could not be deleted.
vserver (STRING): Vserver hosting the volume.
reason (STRING): Reason for the failure.
