cr.snapshot events
CR.Snapshot.Not.Deleted
Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
Severity
NOTICE
This message occurs when a temporary Snapshot(tm) copy created by the 'volume check' command could not be deleted.
Corrective Action
Delete the Snapshot copy by using the following command from "diag" mode: volume snapshot delete -vserver <vserver> -volume <volume> -snapshot <snapshot-name> -ignore-owners
Syslog Message
The temporary Snapshot copy [%s] created by the 'volume check' command for volume [%s] in Vserver [%s] could not be deleted [error: %s].
snapshot (STRING): Name of the Snapshot copy.
volume (STRING): Name of the constituent volume for which the Snapshot copy could not be deleted.
vserver (STRING): Vserver hosting the volume.
reason (STRING): Reason for the failure.
