cap.cache events
cap.cache.corrupt
Severity
ERROR
This message occurs when a corrupt Central Access Policy (CAP) is encountered during access checks.
Corrective Action
Fix the CAP definitions on the Active Directory, and use the 'vserver cifs group-policy update' command to refresh the cache on the cluster.
Syslog Message
Encountered a corrupt CAP for Vserver %s.
vserverUuidStr (STRING): UUID of the Vserver.
cap.cache.not.ready
Severity
ERROR
This message occurs when the system attempts to access a Central Access Policy (CAP) for evaluation during access checks and finds the CAP cache database (DB) is not ready for access.
Corrective Action
Make sure that group-policy is enabled for the given Vserver and the Central Access Policies (CAPs) from the Active Directory (AD) can be applied to file system objects.
Syslog Message
CAP Cache DB not ready for Vserver %s.
cap.cache.update.failed
Severity
ERROR
This message occurs when refresh of the Central Access Policy (CAP) Cache database (DB) fails.
Corrective Action
Use the "vserver cifs group-policy update" command with the "force" flag to retry the operation manually.
Syslog Message
Failed to update the CAP cache DB for Vserver %s. (Reason: %s.)
errString (STRING): Error string.
