cap.cache events
cap.cache.corrupt
- Severity
ERROR
- Description
This message occurs when a corrupt Central Access Policy (CAP) is encountered during access checks.
- Corrective Action
Fix the CAP definitions on the Active Directory, and use the 'vserver cifs group-policy update' command to refresh the cache on the cluster.
- Syslog Message
Encountered a corrupt CAP for Vserver %s.
- Parameters
vserverUuidStr (STRING): UUID of the Vserver.
cap.cache.not.ready
- Severity
ERROR
- Description
This message occurs when the system attempts to access a Central Access Policy (CAP) for evaluation during access checks and finds the CAP cache database (DB) is not ready for access.
- Corrective Action
Make sure that group-policy is enabled for the given Vserver and the Central Access Policies (CAPs) from the Active Directory (AD) can be applied to file system objects.
- Syslog Message
CAP Cache DB not ready for Vserver %s.
- Parameters
cap.cache.update.failed
- Severity
ERROR
- Description
This message occurs when refresh of the Central Access Policy (CAP) Cache database (DB) fails.
- Corrective Action
Use the "vserver cifs group-policy update" command with the "force" flag to retry the operation manually.
- Syslog Message
Failed to update the CAP cache DB for Vserver %s. (Reason: %s.)
- Parameters
errString (STRING): Error string.
