mgmtgwd.replace events
mgmtgwd.replace.node.mgmt.lif
Severity
ERROR
This message occurs when the temporary node management LIF, which is normally deleted automatically, has not been replaced. It should be replaced to free the DHCP address.
Corrective Action
Create a new node management LIF by using the 'network interface create' command, and then delete the temporary node management LIF by using the 'network interface delete' command.
Syslog Message
Temporary node management LIF '%s' should be replaced with a new node management LIF.
lif (STRING): Temporary node management LIF.
